Whiteboard Mode offers two convenient ways to use whiteboards: Gesture Recognition for standard white rectangular whiteboards without recognition stickers, and the Whiteboard Mode button in the client for whiteboards or any flat surface with recognition stickers, allowing for efficient presentations.
Gesture Recognition: Quickly activate Whiteboard Mode using the gestures described in the First Use chapter. This method is particularly suitable for temporary, quick explanations when the whiteboard is in a fixed position.
Client Control: Open the client and click "Whiteboard Mode" at the bottom of the software interface to toggle the feature.
In Smart Whiteboard Mode, recognition stickers are not required. The client automatically recognizes or allows you to manually set the whiteboard area, which is then automatically corrected and displayed in full screen. This mode is ideal for complex scenarios, such as working off-site or using multiple whiteboards.
Note: Before using Smart Whiteboard or background recognition features, please enable Insta360 Virtual Camera. When using this mode in third-party software, you must select Insta360 Virtual Camera as the video stream.
Whiteboard Mode supports the recognition of regular standard whiteboards without corner markers. When paired with recognition stickers, it can customize specific whiteboard areas, such as blackboards, green boards, walls, or monitors. Smart Whiteboard Mode supports both regular whiteboards without stickers and any whiteboard or area with stickers.
Yes. You must set the device to Portrait Mode first, and then enable Whiteboard Mode.
