Connecting Insta360 Connect
- There are three ways to connect the Touch Panel to Insta360 Connect.
Note:When connecting the Touch Panel to Wi-Fi ( ② ) or using an Ethernet cable ( ③ ) , it must be on the same LAN as Insta360 Connect.
• Power on: Connect the Touch Panel to Insta360 Connect via USB A-C cable ( ① ). Insta360 Connect must be powered on. Alternatively, connect the Touch Panel to a power supply with the power adapter and it will automatically power on ( ②③ ).
• Power off: Unplug the USB A-C cable connecting the Touch Panel and Insta360 Connect, or disconnect the Touch Panel from the power supply. The Touch Panel will power off.
- When pairing the Touch Panel and Insta360 Connect for the first time, tap "Get Pairing Code" on the Touch Panel, and a code will pop up on Insta360 Connect. Enter this code on the Touch Panel, and follow the on-screen instructions to complete the setup. You do not need to do this if you connected the Touch Panel to Insta360 Connect via USB A-C cable ( ① ).
Notes:
- Avoid dropping the Touch Panel and keep it away from liquids so as not to damage the screen and internal components.
- The Insta360 Touch Panel has a Human Presence Sensor that turns off the touchscreen after long periods of inactivity and wakes up automatically when someone is nearby.
