Englishinsta360
Deutsch
Русский
日本語
繁體中文
Español
Italiano
Français
한국어
Ace Support
Using the Screen
Front Screen
Once the camera is turned on, the front screen will display the following information:
image image
Camera Status Descriptions
Previewing Battery, storage capacity, shooting specifications, current shooting mode.
Shooting Shooting status i.e., paused, pre-recording, countdown, etc.
Other Footage saving, connecting to app, firmware upgrade, etc.
Flip Touchscreen
The touchscreen's main display shows the current camera shooting mode.
The menu bar shows battery level, storage capacity, and current shooting parameters.
By swiping or tapping the screen, you can achieve the following:
Gesture Description
image Tap the screen
Hide/show information on the touchscreen.
image Swipe left and right in the center
Switch shooting mode.
image Swipe from the right
Enter the shooting parameter settings.
image Swipe up from the bottom
image Swipe from the left
Enter the album page.
image Swipe down from the top
Enter the camera settings.
Shortcut Menu
  1. Storage: Shows the remaining number of photos or the length of video footage that can be stored on the microSD card.
  2. Battery Status: Current battery level of Insta360 Ace.
  3. Shooting Mode: Click the icon and swipe to select a different shooting mode.
  4. Shooting Specifications: See the current shooting mode settings.
  5. Field of View: Change the Field of View.
Click the icon and swipe or swipe left and right in the center of the screen to select a different shooting mode.
Shooting Mode Description
Video Record a video with FlowState Stabilization automatically applied.
FreeFrame Video Apply FlowState Stabilization and Horizon Lock with adjustable aspect ratio in post via the app or Studio.
PureVideo PureVideo improves image quality in low light environments.
Active HDR Record stabilized high dynamic range video.
TimeShift TimeShift video can be used while moving to create a hyperlapse effect.
Timelapse Suitable for shooting static timelapse videos.
Loop Recording Record continuously and save only the last fixed-length segment.
Slow Motion Shoot Slow Motion video with a high frame rate.
Starlapse Shoot and store multiple photos and automatically combine Starlapse effects.
Burst Photos Take multiple photos in a short space of time.
Interval The camera automatically takes continuous photos at a specific time interval.
HDR Photo For high dynamic range photos. Please keep the camera still while shooting.
Photo Take a single photo.
Camera Settings
Swipe down on the touchscreen to view the camera settings. image Insta360
  1. Prompt Sound: Set the camera speaker volume. There are four options: High, Medium, Low, and Mute.
  2. Indicator Light: Turn on/off.
  3. Grid: Turn on/off.
  4. Audio: Switch audio mode. Choose between Stereo, Wind Reduction or Direction Focus.
  5. Timed Capture: Use the Timed Capture function.
  6. Bluetooth Remote: Search for and connect a Bluetooth remote.
  7. AirPods: Search for and connect AirPods.
  8. Settings: See camera settings.
  9. QuickCapture: Turn on/off. Once enabled, press the Shutter Button when the camera is powered off to turn it on and start recording.
  10. Rotation Lock: Turn on/off.
  11. Gesture Control: Turn on/off.
  12. Voice Control: Turn on/off.
  13. Pre-recording: Turn on/off. Save 15 or 30 seconds of footage before you start recording.
  14. AI Highlights Assistant: Turn on/off. The camera finds the best moments from a single video and shows you the highlights to review. Merge them into one video or save each of them as new files. View them on the Album page.
  15. Adjust Brightness: Slide the bar to adjust the screen brightness.
  16. Lock Screen: Tap to lock screen. Swipe up on the touchscreen to unlock.
Shooting Specification Settings
Swipe up from the bottom of the touchscreen to view shooting specification settings.
Shooting Mode Parameters
Video Stabilization, Ratio, Duration, Resolution, Frame Rate
FreeFrame Video Ratio, Duration, Resolution, Frame Rate
PureVideo Ratio, Duration, Resolution, Frame Rate
Active HDR Stabilization, Ratio, Duration, Resolution, Frame Rate
TimeShift Stabilization, Ratio, Duration, Interval
Timelapse Stabilization, Ratio, Duration, Interval
Loop Recording Stabilization, Ratio, Loop Duration, Resolution, Frame Rate
Slow Motion Stabilization, Ratio, Duration, Resolution, Frame Rate
Starlapse Type, Ratio, Duration, Resolution, Timer
Burst Burst, Ratio, Cache, Resolution, Timer
Interval Interval, Type, Ratio, Duration, Resolution, Timer
HDR Photo Format, Ratio, Resolution, Timer
Shooting Parameter Settings
Swipe left from the right edge of the touchscreen to see the shooting parameter settings.
image Insta360
Parameters Descriptions
Shutter Speed The time it takes for light to enter the camera. The faster the shutter speed, the clearer the image.
Sensitivity (ISO) Reflects how sensitive the sensor is to light. A higher sensitivity means the camera can capture more light for a brighter image.
Exposure Compensation Value (EV) In Auto Mode, you can adjust the EV to help with overexposure or underexposure.
White Balance (WB) Removes unrealistic colors and tones so colors are accurately captured in the image.
Low Light Stabilization Improves motion blur and stabilization in low light environments. In extreme environments, the image will be darker and may have some flickering.
Filter Add different color tones and effects.
FInsta360 Ace Priority Prioritizes the fInsta360 Ace for brightness.
Shooting Mode Parameters Parameters
Auto
Manual
Video Filters, EV, FInsta360 Ace Priority, Low Light Stabilization, WB Filters, Shutter, ISO, EV, WB
FreeFrame Video Filters, EV, FInsta360 Ace Priority, Low Light Stabilization, WB Filters, Shutter, ISO, EV, WB
PureVideo EV, Low Light Stabilization, WB Shutter, ISO, EV, WB
Active HDR FInsta360 Ace Priority, Low Light Stabilization, WB FInsta360 Ace Priority, Low Light Stabilization, WB
TimeShift Filters, EV, WB Filters, Shutter, ISO, EV, WB
Timelapse Filters, EV, WB Filters, Shutter, ISO, EV, WB
Loop Recording Filters, EV, FInsta360 Ace Priority, Low Light Stabilization, WB Filters, Shutter, ISO, EV, WB
Slow Motion Filters, EV, WB Filters, Shutter, ISO, EV, WB
Starlapse Filters, Shutter, ISO, WB, EV Shutter, ISO, EV, WB
Burst Photo Filters, EV, WB Filters, Shutter, ISO, EV, WB
Interval Filters, EV, WB Filters, Shutter, ISO, EV, WB
HDR Photo FInsta360 Ace Priority, WB FInsta360 Ace Priority, WB
Photo Filters, EV, FInsta360 Ace Priority, WB Filters, Shutter, ISO, EV, WB
Album Page
Swipe right from the left of the touchscreen to enter the Album page. image
Please click here to contact us for further support.
Was this information helpful?
